Hey guys, will front and rear springs and shocks fit on a Vn? And also will the brake discs, pads and the tie rod ends fit as well? I'm stripping a vs with new suspension and brakes and I want to put them in my Vn, cheers, Josh.
hi iv converted my entire front suspension to vs, it took a lot of work, you will need to use the vs pwr steering rack, or atleast the rack end's and tie rod ends, now the tricky bit is the strut top, you will need to use the original vn one, i used a nolathane full race, one but the hard part is the shock absorber shafts are a few mm larger than vn so you will have to enlarge the hole in the strut bush,i used die grinder, also i found the wheel base in the front was now a bit wider and with the full race strut top i still had way too much camber and had to slot out the mounting holes in the strut tower to get the right alignment. good luck!
oh and for the rear if the vs is live axle it will all bolt straight up.
