Results 1 to 8 of 8
Thread: vn engine noise :(
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    Default vn engine noise :(
    hi all, i have a knock in my engine, that when the motor is cold, can be heard easily, but when the motor warms up, it dissapears, i also have a ticking thats constant no amtter what temperaature, increses with revs, sound like an injector or a rocker, any ideas?? i want it to run quietly (not like an ecotec lol but no ticks or knocks!!)
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    the knock on cold is prob normal as the oil has to pass through the whole engine ect and flows slower when cold, however for the tick, try some injector cleaner with a few tanks of preuim fuel, also give that Nulon lifter tune up thing a go, you just add it to ur oil, i used it and it worked for me with no problems
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    vn_v6's Avatar
    Aug 2009
    victoria
    im 90% sure its injector, but it loud :S i put a screwdrive on injector rail, and then put my ear on it, it seems like the RHS closes to the firewall, if u know what cylinder that is :S how would i go about removing it? i got spares
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by vn_v6 View Post
    not sure on that one buddy, there's prob a write up in the "how to" section, otherwise someone else will be able to tell ya
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    being a VN does it have the anti knock reg fitted to the fuel line ??? should be bolted to the throttle cable plate next to the auto dipstick , looks just like a fuel pressure reg , fitted many of these when i worked for holden when the VN's first came out later models had them fitted as std from factory
    vn_v6's Avatar
    Aug 2009
    victoria
    that ticks the loudest, im sure its that, but i got told it had no moving parts, so i thought it was the injector next to it, its round yeah?
    strgas's Avatar
    Oct 2009
    fuel line hammer is the correct term is was looking for the open and closing of the injectors causes the fuel pressure in the rail and the fuel line under the car to hammer , and produce a ticking type noise thru out the car and the fire wall helps to amplify the noise more , like a drum skin does.
    strgas's Avatar
    Oct 2009
    the diaphragm may have split and no longer reducing the hammer effect
  1. Engine noise not sure wat
    By trivium78 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2009, 12:27 AM
  2. Bad noise from engine! HELP
    By acarmody in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 10:56 PM
  3. engine noise?
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2008, 06:19 PM
  4. Dry noise from engine
    By MontyMan250 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2007, 06:58 PM
  5. engine noise. need help
    By matrix in forum Car Audio
    Last Post: 15-11-2005, 11:06 PM
