Results 1 to 4 of 4
Thread: Wiper question?
    1992 VP vacationer
    Nov 2009
    Question Wiper question?
    what controls the intermittent speed on the wiper system? Is the timing circuit/relay inside the wiper motor or as a separate unit/module some where else. My intermittent does not work properly and makes a buzzing arcing sound just like contact points inside a relay are burnt and worn out. I hear it inside the dash somewhere.
    VP Exec
    Jun 2005
    The timing circuit for the intermittent wipers is in the switch block for the wipers (on the instrument cluster binnacle). You could try a replacement switch block but I have seen dry/broken solder joints on the switches' printed circuit board which is an easy fix.
    1992 VP vacationer
    Nov 2009
    1992 VP vacationer
    Nov 2009
    sweet found it. And yes it does have bad solder joints. Thanks heaps.
  1. Wiper Motor..
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 09:56 AM
  2. Help with VT wiper arm
    By moconn20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2007, 04:40 PM
  3. Wiper arm
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2007, 06:20 PM
  4. just a quick wiper question
    By Bubbles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2006, 09:07 PM
  5. Wiring question for VT headlight/lit wiper washer
    By Muse7707 in forum Electrical Wiring / Questions
    Last Post: 01-02-2005, 06:30 PM
