Results 1 to 14 of 14
Thread: smoking out breathers
    turbo vn calais
    Jun 2008
    Default smoking out breathers
    hi was hopen u guys could help me out iv got a turbo 3.8 i started it up yesterday went 4 a drive and car started fillen up with smoke when i hit boost so pulled over poped bonnet had a look when i give it a rev smoke bellows out the breathers what could that be
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    something is most likely burning a lot of oil, and that smoke is coming from the crankcase.
    you could have a smashed piston, whihc would cause oil to burn via combustion...
    you could have a spun big end bearing or something, causing a heap of heat, and then as it swings through the oil it cooks whatever it touches.....
    first step to diagnose it would be to do a compression test on all the cyls and report back
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I had this problem when i got it on the dyno, started smoking out the Breather on the rocker cover, then i blew a head gasket not long after it, or it was already on its way out, not sure if it still does it hope not.
    ~ VN POWER ~ Click the scales
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I think the valve stems where gone, i have put reco s2 heads on now. and havnt seen the problem, but will be looking out for it.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    also could be a line to the inlet manifold still plumbed in like the one under the throttlebody to the manifold will blow boost clean through the bottom end
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Yeah, i made sure i put a Bung on the T/B and then i just have a breather coming off that, but if the breather is off the Rocker cover it wouldnt be attatched unless he just drilled a hole in the Rocker cover cap and put it on there for the s1, s2 its on the manifold.
    vp
    Feb 2009
    в∞ѕтεכ √&
    Jul 2008
    NZ
    it is most likely they allways blow into the valley and smoke like hell
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Still got 154rwkw and i had a feeling the head gasket was letting go abit, not long after that it was dead. i think on my VID of my car on the dyno you can see the smoke abit.
    turbo vn calais
    Jun 2008
    i had i feeling it was going to be something along those lines im getin compression testd tomorrow
    this wiil be second motor first one i blow both head gasets cracked two pistons and blew rear main seal
    в∞ѕтεכ √&
    Jul 2008
    NZ
    does it have bigger injectors and a tune or it is allways gonna happen
    GM GEN3's Avatar
    GM GEN3 is offline GM GEN3
    legs ATM
    Sep 2008
    S.A
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Quote Originally Posted by dodgee69 View Post
    I also blew the head gaskets on NO3 and it melted the Manifold gasket and then popped out the rear main seal, lucky no piston damage, that i know of
  1. [NSW] F.s- tacho, diff, oil breathers, turbo timers, holley blue
    By BLOW6 in forum Parts And Other Items For Sale
    Last Post: 17-02-2009, 04:38 PM
  2. oil breathers on ecotec?
    By vx6 in forum General Discussion
    Last Post: 30-09-2008, 01:52 PM
  3. Smoking VN
    By SiLeNt-SoN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2007, 09:09 AM
  4. Fuel Tank Breathers
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 10:59 PM
  5. Smoking.....
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2004, 05:23 PM
