hey guys, i was cruising home the other night and everything was running fine. i stopped at the lights and when i took off, i noticed the speedo was jumping around. it was still working but jumping around 10-15k. then all of a sudden it would go to zero and back up again and dance around. what could this be? could it be the speedo sensor on the box? hasn't shown up any error codes at all. its a vp v6 with a t5 behind it. any help would be muchly appreciated.
thanx,
George
yeah definatly speedo sensor same thing happend to me. went to a wreckers cost me 10 bux for a secondhand one. chucked it in all good.
Not necessarily the speedo sensor or the speedo actuator in the dash.
Those exact symptoms on my car turned out to be a short between the reversing light and indicators in the rear harness. Easy way to tell is to check your reversing light fuse. If it's blown then that's your problem. My short turned out to be in the towing plug thing loom. You can unplug the rear looms and plug them back in one at a time from the boot to see which one is at fault. On VN-VP those rear looms are buggers for failing anyway and only cost $20-$30 new.
Warranty Void
all reverse lights, tail lights and indicators are working 100%. ill check out the speedo sensor tomorrow. are they the same manual and auto?
George
yip vn vp auto and manual are the same
yea i chucked it up on the hoist today. one of the wires had broken on the speedo sensor. replaced and all works well.
George
A failed speedo sensor fuse will give the same problem (for this threads future reference)
