Results 1 to 6 of 6
Thread: VQ driver side passenger power window.
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    Default VQ driver side passenger power window.
    Mate has a vq stato and the power window wasn't going down at all. Stupidly enough I played with the switch and got it to go down but now it won't go up?any way to fix this or bypass it to put it up for the night? Any help asap would be great
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    most power windows afterwhile mine do it in my statesman just keep fidling with the switch
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    push down evenly on the up and down buttons at the same time, so its like you're pushing the whole switch into the dash. then slowly lever it into the up position and it should contact.
    happened to my vl calais
    93 VP Ute, V6 5 Speed
    STEALTHY™'s Avatar
    STEALTHY™ is online now So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Also check the rubber seal. Sometimes one side falls into the channel, making it hard for the window to go up or down.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Mar 2009
    I've noticed now that when u push the switch the little led light turns off on the switch. What could be causing that?
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by jimbojones889 View Post
    If you mean the power window light, then thats a switch problem, easily fixed (although they have green lights, unless its been modded with red ones)
    cheers sexy
  1. driver side window broken
    By VRoooom! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2009, 05:02 PM
  2. VN Driver side window Terrors
    By Cynstr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 04:55 PM
  3. Driver Side Window Help
    By boostdvl69 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-01-2007, 07:43 PM
  4. VX driver side electric window
    By robj in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-11-2005, 11:08 AM
  5. water leak driver side passenger door!
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2004, 03:39 PM
