hi all i have a v6 vp and just recently it has become slugish. i had a problem with it and i turned out that it dropped a cylinder cause of a spark plug, i fixed that and now it still idles low it dropes from 900rpm to 800rpm then back to 900 and drops and so on. and it dnt accel as hard and it feels slugish. i have a pod filter on but that has been on 4 about 5 weeks and the problem only started last week, i was just wonderin any tips 4 fixin it like does it need a service and tune or somethin, thanks chris
um no i dnt i will change my pod setup but do u really think that could be the problem.
oh and when its ideling low it shakes alot and its really anoying. but i did have my pod setup different eg. running from the original black pipe with a slinky hose to the slits in the front of the front bumper. and i think it was still doing it then
try replacing all your plugs and ignition leads. you can test your leads with a multi meter. more than 10K ohms I would chuck them and get new ones.
i noticed the throttle cable was loose so i tightened it and now its good and now im runnin my pod like before aka to the front bumper so yea cheers guys
