Results 1 to 5 of 5
Thread: Lower balljoints and Top Stut mounts
    VN Executive
    Apr 2007
    Wellington, New Zealand
    Default Lower balljoints and Top Stut mounts
    Morning all,
    I just failed my warrant of fitness on Lower balljoints and play in Strut top mount.
    Are these hard things to fix? I searched for info about the balljoints and they seem rather simple to replace (if you can get them out) but i dont know anything about the Top mount.
    The top mounts the rubber thing between the top of the strut and the strut tower just incase i have got the wrong name for it.
    Any help would be awesome as the garage closes on thursday next week
    1992 VP vacationer
    Nov 2009
    as far as I understand you compress the springs and undo the strut insert nut located under the plastic cap on top of the strut mount. then you got the 3 nuts on top the hold in the mounts to the body. I have never done it before but that's all I know. mine need replacing too. I still need to get the strut tops and power steering rack and I have every part new ready for a complete suspension rebuild.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    The lower control arm has the ball joint in it, it's best to replace the arms as a changeover as the joints are press fit and that's not really a home mechanic job. You'll get new inner bushes too that way. Should be about $80 each changeover. Ask about new swaybar bushes etc at the same time if they are worn or you want to put in better links.
    Strut top is best done with aftermarket adjustable tops if you want to save some $$$ down the line...(with wheel alignment and tyre wear)
    You could do the lowers yourself easily but you want to be careful playing with spring compressors for the strut tops. If you do it yourself read the spring compressor instructions carefully and use chassis stands so you don't die.
    Remember you will need a wheel alignment afterwards.
    Warranty Void
    VN Executive
    Apr 2007
    just ended up taking it to my mates work shop to get it done before xmas.
    Cost me $400NZD though labor is the killer!
    Thanks for you're help everyone.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    $400 isn't a bad price at all - don't be upset with that
    The 1972 HQ Kingswood
  1. lower steering balljoints?
    By Panama in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-06-2009, 05:37 PM
  2. PoLL: lower back or lower front????
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2008, 09:55 AM
  3. 253 on 202 mounts?
    By -[VNSPAK]- in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2006, 12:53 PM
  4. Stut Tower Bearing
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2006, 11:58 PM
  5. VyII stut brace into VT
    By dagsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2004, 11:33 AM
