Results 1 to 5 of 5
Thread: Are torgue converters all the same?
    vn wagon
    Dec 2009
    Default Are torgue converters all the same?
    Hi guys a have a problem , it would be great if anybody can help.
    I have a vn series 1 which has a good auto but the engine is tired.
    I have purchased a vr engine and auto both in good con.
    The question is = Can i use the torgue converter from the later vr electronic auto and install it behind my old vn -vp auto
    The reasion - My torgue converter on my old auto stops locking up once warn.
    The auto works fine apart from that, but we tow a caravan once a year
    so it would be good to have it working.
    If any one has any Ideas l would be thankfull
    VP Executive R-spec
    Jan 2005
    I don't know if the convertors are the same but they probably are. But I do know that it's unlikely the lockup failure on the convertor is the convertor itself. It might be, but it's more likely to be a problem with one of the sensors, TPS, Coolant sensor or even the ecu itself
    V6 VT Commodore
    Aug 2009
    Tamworth, NSW
    just a question, might be stupid but .... have u thought it could be one of the bands ?
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    I am pretty sure (about 90%) that all the v6's 4l60's/T700's used the same torque converter.... Only the internals of the trans where electric......
    Pretty sure but not 100% (maybe give a couple transmission places a call? or look up some part numbers?)
    vn wagon
    Dec 2009
    Default thay are
    Quote Originally Posted by greenfoam View Post
    Thanks for your help. I think you could be right about the sensors. Thinking that the engine is that tired it may not have correct manifold vac etc.. (the computer cannot control a tired engine)
    Found on ebay so one selling hi stall torgue converters , vn to vt all the same. Will fit the vr converter just in case.
    Thanks Mark
  1. High Cat Converters
    By VZ06 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-04-2009, 11:19 PM
  2. Cat converters
    By Emackulation in forum LSx Development and Modification
    Last Post: 19-01-2009, 04:19 PM
  3. Cat converters size?
    By dan-0 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-09-2008, 05:22 PM
  4. Stolen cat converters
    By whitevrboi in forum General
    Last Post: 12-06-2008, 04:14 PM
  5. Super Cat Converters
    By thomasr in forum V6 Development And Modification
    Last Post: 17-03-2005, 07:47 PM
