Results 1 to 6 of 6
Thread: will a vp engine fit into a vn ??
    1990 vn s series
    Dec 2009
    N.W Suburbs Melbourne
    Default will a vp engine fit into a vn ??
    will it work and if yes what will i have to use from the vp example... exaust loom etc
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Yeah. V8 = same, v6 slightly different but no biggee.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    1990 vn s series
    Dec 2009
    Reaper's Avatar
    Aug 2004
    No - I presume you are talking about V6??? You just need to change more stuff.
    Reaper
    Reapers Black VP SS
    1990 vn s series
    Dec 2009
    yeah im talking bout a v6. would you be able to give me some suggestions on what needs to be changed. like can i use the vp loom thankyou heaps for your time much appreciated.
    VN Berlina
    Aug 2007
    Carrum Downs
    I've just been through all this about 2 weeks.It was a bit of a mission but heres what i found
    -Either Change the loom or extend a couple of wires here and there for sensors ie. water temp
    -If series 1 has aluminium pan instead of big **** off heavy bellhousing prob easier to keep that for series 2 engine much easier to access.
    -swap radiator and overlfow bottle as can't fill series 2 engine without it because different hose postioning and a few different hoses ie. top radiator hose and top heater hose to back of inlet manifold.
    -anything from s1 engine can be swapped on to tall s2 engine if needed except for injector rails won't fit different inlet manifold
    Thats all i can think of off the top of my head i'll look at my photos and add more details if i find anything.
    As for exhaust i replaced mine with extractors at the same time so i didn't really pay attention but i'm fairly certain is all the same where it counts.
    Hope that helps i will hopefully post some pics soon for others wanting to do the same thing
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Upper Engine Cleaning on old Engine (Unopened)
    By Jesterarts in forum The Pub
    Last Post: 17-02-2010, 09:02 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
