I have replaced and or changed everything that i can think of that would cause the idle of my car to hunt.
All replaced:
- IAC
- TPS
- O2 sensor
- All vacuum hoses
- Brake booster was leaking, replaced and it improved a bit
- Injectors
checked all points of vacuum
When the car was running dual fuel it idled perfect on gas but hunted on petrol. Since then i have removed the gas system and replaced the engine with a fresh one.
Could it have had some tweaks in the tune up to suit gas better? In other words, could the hunting be a problem in the tune?
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
map sensor, same as the V6 ones, usually you can tap on them when the idle is playing up and it runs fine for a minute then goes back to hunting again
I was in such a mental mess over you listing all that stuff and not changing the map sensor that I couldn't reply. Lucky benny was up for it![]()
checked your manifold gaskets ??? vacum reading ??? is your PCV blocked or restricted ??? checked your engine breather pipe ???
thanks for replies
strgas: but the thing is.... it hunted on petrol on the old motor as well! pcv and breathers are clear/ new.
greenfoam: i have only really mechanically switched on to ecotecs, so the map sensor didn't scream out to me straight away.. my bad. i shall try that.
Are series 1 v6 and v8 map sensors the same by any chance?
any map vn to vr v6 or v8 they all the same
go the MAP,,,,,,,,,,,,,,,,,,,,,,,
