BBQ fuel, in the VN, every time i drive on the BBQ fuel, the engine light comes on ?
The car is all good, nothing wrong, just the light keeps coming on when i drive, anything to be concerned about ?
adding in, that the engine light dosent come on when i run straight petty ?
running on lpg will always bring on the check engine light due to the mixture control being out of adjustment . wire in a relay to turn off the check engine light when on gas is my advice if its annoy you that much
as above. check error codes - oxy sensor lean - that's just what happens when you run gas. i believe that factory fitted vns with lpg actually had this code turned off on the memcal
