Results 1 to 7 of 7
Thread: Cruise control.... plz help..
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Default Cruise control.... plz help..
    4 some reason the cruise control in my vn commodore keeps blowing the fuses whenever i turn the key 2 start the car..? Even when the ruise switch is turned off they still blow? Any help?
    vnss
    Jan 2005
    s.e melb
    VH SS
    May 2009
    Toowoomba, Qld
    what other circuits share that fuse ?
    might not be the cruise control blowing the fuse
    try disconnecting the cruise module connector (under the bonnet - black box with cable going to throttle body, located somewhere near the l/h/f guard.)
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    It only runs the power windows which i dnt have? Its factory fitted and i have never had any trouble with it before?
    vnss
    Jan 2005
    s.e melb
    yeah disconnect it like darren said and see if it still blows the fuse.
    gotta start somewhere..
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Something is drawing too much power, that means a short - have you done any work on the car recently? Installed something using self tapping screws? have a good look at the loom attached to the cruise unit, is insulation worn away anywhere, is it rubbing on anything? After unplugging cruise module check fuse like the other guys suggested. If the fuse doesn't blow with the module unplugged then the fault is almost certainly within the module, ie a relay stuck shut and constantly powering the electric motor. (If the motor reaches its limit of movement and is still on it draws more and more power until the fuse blows)
    Don't put in a heavier fuse without knowing what's going on, you can make things much worse that way.
    Warranty Void
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Well now 4 some reason it only blows the fuse once the car gets hot?? if its cold it doesnt happen?
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. Cruise Control....... how to set ??..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 10:21 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
