+ Reply to Thread
Results 1 to 5 of 5
Thread: Steering Knock on VP Commodore
    VP 3.8
    Mar 2009
    Default Steering Knock on VP Commodore
    G'day all
    I have a VP Commodore that steering knocks when turning right hand side full lock
    It is basically doing the same as what a front wheel drive car would when the CV's are shagged, ie: the harder right i turn the worse it knocks, or if i turn easy right and avoid u-turns, i can avoid making the steering knock
    what could be causing this?
    VS Berlina 3.8
    Dec 2008
    How are your swaybar link pins?
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline **** on *** and ***** Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    Hilux SR Dual Cab Mine Spec
    Aug 2006
    Bunbury, WA
    Sounds like it could be the rack end. The bit that comes out of the rack and connects to the tie rod end.
    It's not how you spend your money that matters, but how you spend your life.
    VP 3.8
    Mar 2009
    cheers, will get under the front and check it out
    VP 3.8
    Mar 2009
    turned out to be a split swaybar link pin bush. threw in all new nolathanes and that fixed it.
+ Reply to Thread
  1. Steering knock noise
    By hingo1983 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-10-2009, 02:20 PM
  2. Vn steering knock
    By hoffy1961 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2009, 11:32 PM
  3. Steering knock noise
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2008, 09:59 PM
  4. Power Steering Knock
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-11-2008, 03:51 PM
  5. Slight Knock In Steering
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2006, 09:09 PM
Tags for this Thread
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
