Results 1 to 6 of 6
Thread: Brake Upgrade Turbo vg
    VG Exec
    Oct 2007
    Default Brake Upgrade Turbo vg
    Need to upgrade brakes thanks to turbo motor.
    wanting to run vs hubs rotors and caliper and steering nuckle.
    does anyone know how involved this is. do you need to change the mounting for front shockies and use a vs bottom frame?
    VG commy
    rb25det and running gear
    shaved lines, turismo blue
    VS Berlina 3.8
    Dec 2008
    Go for a VT setup, VS isn't really much of an upgrade. Have a search around, it's been covered a fair bit.
    VP Executive S2, VL 5sp Berlina Wagon
    May 2008
    Down South, Adelaide
    screw the vs setup, buy a VT conversion kit of ebay roughly between $600 - 650, includes adapter hubs, new rotors, new calipers, braided lines, brake fluid and pads im pretty sure.
    Easily the best and easiest upgrade, and its pretty cheap aswell
    Sleeper Wagon - In the Build
    VP Executive series 2
    Check out My Ride
    Current Mods
    Widened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy Tune
    Future Mods
    New Car
    Wanted
    MONEY!!!
    VZ AWD One Tonner
    Jul 2006
    or even better, the flex-less VE calipers
    VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by gslrallysport View Post
    go this setup, parts are cheaper in the long run
    u can always look out for the group A big brake upgrade 328mm rotors and twin pots, but getting replacement rotors are expensive, trust me.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VE upgrade is the better option for sure, it comes in two different sized rotors depending on what size your rims are. No need to replace the booster or master cylinder either.
    Visit my Facebook page
  1. VT BRAKE UPGRADE - looking for brake line adaptors for vh to vt
    By rusty05 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2009, 02:54 PM
  2. VP Brake Upgrade
    By LowVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2008, 02:59 AM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. VP Brake Upgrade
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2004, 02:59 PM
