Results 1 to 8 of 8
Thread: HELP! URGENT! VP oil light
    VT Calais 3.8
    Nov 2008
    Default HELP! URGENT! VP oil light
    Hey guys, I'm driving north for Christmas and every time I get the car up to speed for a little while the oil light comes on.
    I'm also getting some vibration in the footwell under load.
    I just changed the oil and filter 2 days ago and when I check the level it shows it's got heaps (in fact it shows as being over full even though I put in the same amount of oil as usual (5 liters)
    What can I do to check that it's not going to explode?
    VP Calais 5sp/VP S2 Wagon
    Dec 2009
    Toronto, Newcastle, N.S.W, Australia, Earth, Milky Way.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Gaz_3110 View Post
    Did you Hose out under the bonet After changing the Oil?
    Unless he's spilled oil absolutely everywhere, this shouldn't matter. Could be a faulty sender?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    How far over full is your oil? If your oil level is too high, the oil can churn under load, causing poor flow and a drop in oil pressure.
    The 1972 HQ Kingswood
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    umm, seriously, WTH????
    Quote Originally Posted by Morton View Post
    Dec 2009
    Ive been told it can fry your Oil pressure switch. My oil light comes on when i hose it out, Give it a boot around the block and run for 5 and it goes off.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    I reckon u have a sludge buildup and its blocking ur pickup which is common and VERY serious in the buick V6's. My bros motor threw a rod, a mate has had 5 of em go and a mate of mine up the road has had one seize cause of this. everyone though it was low oil or faulty sender for these but it was sludge. Flush the oil man, engine flush, diesel anything. Best thing to do is take the sump off and clean it out but thats a big job but u gotta get some sort of flush through it or else will seize or worse.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Morton's Avatar
    May 2006
    If there was enough gunk in there to block the pickup, I'd be reluctant to use any form of oil flush. If anything, it's more likely to dislodge larger chunks of rubbish down from the rockers and block things up well and truly.
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. URGENT URGENT alternator wiring
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-09-2008, 01:10 AM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. VC brake light prob. urgent!!
    By The Darkness in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-11-2007, 06:28 PM
  5. urgent! monaro tail light prices
    By slidways in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2006, 09:36 AM
