my vn has a crack in the body where the front drivers seat bolts in does this make the car un roadworthy?? any ideas on how to fix can i weld it or should u just put a metal plate underneath it
I would be worried the car has other damage, if it has a split floorpan.
yes that is something that would be considered un-roadworthy.
get it fixed as soon as possible too if you can
Has it been in an accident before you bought it?
Been there done that. I stripped the interior and got a panel beater to weld it up. Then I just got a new nut and bolt from the hardware and made a large washer out of a thick-ish metal plate to suit.
Bloody previous owner used a semi-threaded bolt which couldnt tighten completely, so the seat was bashing around for god knows how long.
http://forums.justcommodores.com.au/...330-large-.jpg
http://forums.justcommodores.com.au/...584-large-.jpg
