Results 1 to 5 of 5
Thread: VP V6 Harmonic balancer making noise, help!
    VP exec
    Feb 2009
    Default VP V6 Harmonic balancer making noise, help!
    Vp V6 Harmonic balancer making a metal clanging noise while running, took the fan belt off and tried to rotate it and it gets to a point and just stops moving......is this somethin that is easy enough to replace at home or do you need to get mechanic to do it?
    cheers Dallascowboy
    VN Commodore
    Mar 2009
    Its easy to remove at home if you have the right tool, i dont know what its called but it looks like a claw with a screw in the midle that grabs the harmonic balancer and pulls it off the crank shaft, i saw one st super cheap for around $75. After you replace the harmonic balancer either with a new one or one from a wrecker the bolt that secures it needs to be pretty damn tight, the book says something over 300Nm, but a rattle gun or long braker bar will do the trick. pretty easy and evern if you buy the tools it will probly work out cheaper than taking it to a mechanic.
    VS Senator
    Oct 2009
    i wouldn't get one from a wrecker. it might not last that long and cost almost as much as a new one spend the extra few dollars and get a new one.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Using a rattle gun won't guarantee removal of the centre nut (25mm from memory). You may need to use a long socket bar (with suitable size socket in place) get underneath the car put socket onto nut and end of bar against sub frame. Quickly turn the ignition on/off to cause engine to rotate (hopefully you have the bar on the correct side of the sub frameotherwise it can spin around and cause untold damage). Make sure that the engine can't fire. This method will always work with stubborn nut. Don't waste your time with a secondhand one. Take yours to auto parts store and get a change-over.
    VP exec
    Feb 2009
    balancer replaced, problem solvered!
    thanks for the help guys!
  1. what does the harmonic balancer do
    By vnbelina in forum General
    Last Post: 27-12-2009, 03:19 PM
  2. [SA] F.S. Harmonic Balancer 253/308/304
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 04-11-2009, 10:13 AM
  3. harmonic balancer
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2006, 08:37 PM
  4. Harmonic Balancer...
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 08:09 PM
  5. Harmonic Balancer
    By PIMPIN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2005, 11:21 AM
