Just got my rebuilt s2 engine running in my s1 vn berlina. had to screw with the leads and coil pack to get right timing and it seems to be right but it idles extremely rough for about 30 seconds before flattening out and becoming a smooth idle then no more than 30 secs later it dies.
using s1 computer and gearbox, s1 loom modified s1 coilpack everything else s2 if that helps
trying to get it running before end of tomorrow so fast answers would be much appreciated.
Thanks guys
Also could this be due to the fact that i'm using s1 computer?
yes, get a series 2 computer. ive done the same conversion and you need a seris 2 computer.
thanks heaps mate.
also do i need s2 coil pack?
i've seen alot of talk about DFI module under coil pack but can't see such a thing under mine do you know if that would also cause problems?
When i did my conversion, i used a series 2 loom and computer and it all bolted and pluged straight up, had to change the cooling system a bit, the engine sounded like a piece of shit when it first started because oil had to pump thrugh, and it wasent 100% until after the run in, 1500km with run in oil first 1000 km took it steady and dident get about 80kmh often, then the last 500 some hard driving to get the rings to bend. and now it runs well all the time.
Thanks mate.
will pick up s2 comp and coils tomorrow and let you know how i go
i did the conversion to
what u need is
vp-vr cooling system
s2 ecu loom
s2 oxygen sensor
using vr coil pack
im still using my s1 ecu n foamys chip thats for my s1 motor
runs perfectly
i mainly got my parts from a vn s2 thats running my s2 vr motor
