Hey guys.
Got a VP BT1 5ltr and the power steering high pressure line has had a hole worn through the metal line and im just wondering if the metal line fron the rack to the pump is the same on a V6 as the V8?
any help would be great.
BAD COP!! NO DONUT!!
It will hold the pressure but not sure if there the same length..
Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
I had the same thing happen to me on christmas day so I just cut the metal lines at the break and slid some old braided line( use any high pressure hose thats the right size) over it and clamped it down ,havent had any leaks yet
couldnt you just use high pressure rubber lines and cut to suit?
