Results 1 to 5 of 5
Thread: Sanding the car
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Sanding the car
    Whats the best grit sandpaper to use when sanding a whole car back,car has been scratched with a knife or somthing sharp.
    Whats best to use when sanding it back, by hand,by sander or drill sander?
    Real cars don't power the front wheels, they lift them
    VP Executive R-spec
    Jan 2005
    I wouldn't sand a VN back to metal if it's rusted in the scratch then sand that area only, as small as you can. Just use wet and dry. The thing is VNs have very good rust proof coatings on the sheet metal if you sand that off they wont last any longer than your typical 1970s car (which wasn't long)
    vnss
    Jan 2005
    s.e melb
    mate i suggest you go into a panel shop and speak to a painter if the boss lets you cos i could sit here and type for ages explaining the procedures, do's and dont's and it will confuse the shit out of you.
    and it wont hurt to give google a shot either
    gl
    VT SS 5.7
    Mar 2005
    Goulburn
    no worries thanx guys
    yon
    yon is offline
    vn
    Mar 2006
    if u want a good answer give a good explanation.pics would help,then wildss can tell u how to fix it.
  1. Sanding & Spraying
    By Cobez in forum General
    Last Post: 04-05-2007, 11:20 PM
  2. Bonnet Sanding
    By SiLeNt-SoN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-10-2006, 07:56 PM
