Results 1 to 3 of 3
Thread: VN Calais Boot Issue
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default VN Calais Boot Issue
    Okay so I went to open my boot by using the button in the glove box as per usual, doesn't open; nothing out of the ordinary really normally I need a mate to push on the boot to get the lock to pop open. That didn't work, even after pushing, shaking, bouncing and few foul words. My boot lock isn't the same ignition and door key, so it doest open, and I wasn't give then key for it. I have my sub box blocking getting into the boot from inside the car. So anyone else have this problem? or know how to get my boot open? Even stop it from jamming like a btch almost evertime I close it?
    Dirbatua's Avatar
    Dirbatua is offline Say No to Chev Badges
    VX SS, VR Clubsport
    Apr 2003
    S/e Victoria
    its a VN, take an appropriate size flat head screwdriver to the boot lock, shove it in and turn it, will pop open soon enough with a bit of jiggling.
    The lock is usually still good cept if you stuff it, in which case remove the lock and put a new one in that you have the key for
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    My electric boot release often needs a good jiggle/ bump on the boot to work, easy fix for this? I don't find it important/annoying enough to play around with on my own and risk breaking things like I usually seem to
    WTB: mulberry VN interior parts
  1. vz calais issue
    By calais0904 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-11-2009, 06:34 PM
  2. vx calais issue
    By brockee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2009, 10:06 AM
  3. boot opening issue
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2008, 10:16 AM
  4. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  5. Boot install issue
    By G4orce in forum Car Audio
    Last Post: 02-05-2005, 05:44 AM
