Results 1 to 6 of 6
Thread: Any Help?
    VS Commodore Ute
    Nov 2009
    Default Any Help?
    hi guys, one of my mates vp wagon seems to sputtering almost as if it is being choked of air or petrol. i replaced the fuel filter and the problem still occured, replaced plugs and it fixed the problem for the time being, it has now come back after about 15 mins of driving! ive been old that the leads have been replaced recently. could it be the injectors? any ideas would be great. thanks
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Personally, do the ECU error code check .
    Could be not sparking good enough maybe?
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VS Commodore Ute
    Nov 2009
    how do u go about doin an ecu check? what would cause a lack of sparking?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Checking your Computer for Faults (VN - VP)
    there ya go .
    As for sparking, the Coilpack or the DFI may be to old..And can die.
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    Have you checked the pipe leading from the TB to the MAP sensor? I had issues and found the ends of this pipe to be cracked. I trimmed both ends back 7mm, cleaned it up and put it back in place and no issues since then. Although the ECU error code check would save a lot of issues, it could be that one of the sensors is on the way out.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Dec 2009
    check your spark plug leads for either an open circuit or excessive resistance and check your fuel pressure.
