Results 1 to 10 of 10
Thread: trouble with lowering vn please help
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Exclamation trouble with lowering vn please help
    hey iv just bought super low king springs iv only put them in the rear atm and the left hand wheel rubs on the wheel under guard just the left its got me stuped can any1 give me some advice on wat 2 do
    cheers
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    Have you just installed springs and nothing else? Did you install an adjustable panhard rod and shorter shocks? The stock panhard rod will now be too long so an adjustable number is required to center the diff. Without it the car will crab. For that matter have you got some shorter shocks to keep the super lows captive in the rear?
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    Jan 2010
    thanx for ur reply iv installed the rear springs and short shockers but not the panard rod. wat do i hav 2 do wen i get it do i just hav 2 change the stock 1 4 the adjustable 1?
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    Well, thats the first step. The new rod should come with bushes etc, make sure they are greased properly before you install the rod. You'll then need to adjust it to center the diff. Some of them are 'on car' adjustable which is alot easier, you can crank them to the correct setting without constant and annoying removal and installation. If you've got the option get the on car type!
    To center the diff I made a chalk mark down the centerline of the car (on the fuel tank from memory) and aligned the diff/driveshaft with that. Use axlestands or car ramps if you have them, if not you'll need to make sure the alignment sits right with the car on the ground. If you use body stands/jack pads and make the alignment without the weight on the axle/suspension then if will swing back out on the ground.
    Jan 2010
    ok thanx. i havent done the front yet im waiting on shortend struts do u think i will hav any probs with alignment or rubbing on guards?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by nudge701 View Post
    Not unless you have very large fron wheels and tyres.
    You will however with super lows on the VN scrape its guts on small pebbles LOL.
    and 3 Dangerous non ABS VN's
    Jan 2010
    im also still a little confused bout the panhard rod amd the alignment do no any sources were i can find detailed instrustions
    Jan 2010
    88GreenVN's Avatar
    Jun 2006
    The pan hard rod is 2 bolts - 1 at each end. Takes about 20 mins to swap in the drive way.
    Jan 2010
    sweet like iv got 18'' osaka rims there 235/40 i would like 2 lower it 2'' with king springs so if i put the springs in and the shortend shockers and the panhand rod will i hav any rubbing wat so ever even wen goin over large bumps??
  1. in big trouble !!!!!!
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2009, 02:21 AM
  2. Bob was in trouble.
    By VS_Pete_1 in forum Jokes/Humour
    Last Post: 18-12-2008, 09:14 PM
  3. lpg trouble
    By jamie_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2006, 01:25 PM
  4. Having trouble
    By aw006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2006, 07:21 PM
  5. car trouble
    By panther7278 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-03-2005, 06:15 PM
