Yo
Who's removed their intake restrictor bellmouth thing? I was thinking of doing it to mine but I'm just curious to know if it will make a noticable gain.
also my problem is that once it is removed, you have to reset the computer my holding the car at 3000RPM for 10 seconds... correct?
I don't have a tacho... so what do I do? haha
cheers fellas![]()
93 VP Ute, V6 5 Speed
Try the v6 development & modification section
The bellmouth has been done to death dude, a search is your friend. And yea, 3000rpm for 10 seconds resets your IAC valve. No tacho? How quickly can you count?
JetSpin Racing Team Mantre:
"F**k safety, I'm in a hurry"
How am I meant to know that I'm holding the accellerator at 3000rpm is what im trying to say....No tacho? How quickly can you count?
most who've taken it out have said that all they got from it was a worse idle. not worth it.
Yeah i got a worse idle but it does seem a little more responsive down low. But i could just be tripping out. Ill be removing it out of my new motor wen i get it this week. Didnt know anything about holding it at 3000rpm. Nothing bad has happened to my Vp because of it been removed.
^^ yeah well i'm pretty sure the IAC resets itself after a bit of driving anyway![]()
no matter wat people say their experience is with the bellmouth in or out, it reduces the area for air to enter the engine and if your chasing more power then the area for air to enter must be biger.
what do u have to pullout and where is it cheers boyz?
Its the plastic bell mouth that sits inside the intake manifold its just after the bent piece of tube after the throttle body.
without the bellmouth, cylinders 5 & 6 run leaner causing rough idle. that's why the bellmouth was put on the s2 motors - to better distribute the air to make the rough buick a little smoother. this cannot be fixed with a tune. you are guaranteed a worse idle with it out, however as for the gain in power that's up to you to decide for yourself
but yes, do a search. the information is all there
Removing bellmouth
i can see any reason for leavin it in if you want more power, biger hole = more air, which is good.
