Results 1 to 4 of 4
Thread: Inside Door Removal
    Blown-VH is offline VH Wagon
    VH SL Wagon
    Nov 2009
    Question Inside Door Removal
    im trying to take the inside of the door of my step dads vn. i get most off but the rest gets stuck and i dont know how to get it out. the book tells me shit all so i need help. trying to put rubber back in window as its common for commdoores for it to come out. please help me guys in need of a big help here. cheers p.s im used to me vh so vn is a big step haha
    VN Wagon
    Feb 2005
    From memory.
    Pull up door lock tabs. Use a thin bladed hook to pull out red/orange cover (tricky bit). The door lock tab should then come off.
    Unscrew surround to door lock tabs.
    Pry off cover to door handles and unscrew them.
    Use a tool or thin pliers to disengage window winders clips and remove window winders (little bit tricky).
    Working from the bottom, carefully pull door liner away from door. You will find a number of blue press studs holding this on. Be careful as they break.
    Finally unhook the top lip of the liner from the door.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    For the windoe winder removasl - a bit of rag under the handle forming a "U" shape and work it from side to side a little. May take a few goes - but this is how I've removed the winders on the VN for years.
    and 3 Dangerous non ABS VN's
    VH SL Wagon
    Nov 2009
    cheers guys. will take a look at it on the weekend and mlet you's know how i go. thanks again
  1. Rubber Inside Door
    By red rock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2006, 07:48 PM
  2. VT inside Door lights??
    By blunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2006, 10:48 PM
  3. Inside door locks
    By Conan 12 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2005, 04:55 AM
  4. Rattle inside door on VS
    By ntl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
  5. inside the vl calais door
    By nick 8x in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-08-2005, 08:04 PM
