Results 1 to 4 of 4
Thread: VN 5 litre, trans problem , i think please help me!!
    vn calais 5 litre
    Apr 2008
    Default VN 5 litre, trans problem , i think please help me!!
    hey guys i took my car out today and my trans started playing up on me what happens is it wont change from first to 2nd until it hits 4000rpm and same for 3rd n 4th it usually changes gear when it gets to 2 n a half 3000 rpm. also when im driving at about 60k ive got like what seems to be a clutch and play in acceleration for example im sittin on 60 2000rpm if i back off it just revs untill im back at 2000rpm again like its slippin but its not. ive got a stage 2 shift kit in it as well. im pretty sure the trans may be on its way out but i dont want to take the car to jus any trans joint an get ripped off. so any help would be much appreciated thanks matt.
    VN Commodore
    Mar 2009
    vn calais 5 litre
    Apr 2008
    ive owned the car about 6mths it hasnt been serviced since shift kit was instaled 12 mnths ago im not sure about the kick down cable how would i go about checking or adjusting cable
    thanx matt
    VN Commodore
    Mar 2009
    mine was playing up sort like how you described so i serviced it and tightened my thrttle cable and kickdown cable and now its running pretty good. Check your trans fluid level, drive it till it registers normal driving temp then see if it reads Full Hot on the dip stick.
  1. Trans problem
    By StockoVRWagz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2009, 07:18 PM
  2. FS Vic: EFI 5 litre V8 conversion (Auto trans)
    By deathsminion in forum Parts And Other Items For Sale
    Last Post: 15-11-2008, 08:46 PM
  3. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  4. trans problem
    By muffman001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2005, 10:14 PM
  5. trans problem
    By sk8er in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2005, 03:52 PM
