Results 1 to 10 of 10
Thread: Defect
    1993 yota 4 runner sr5. Sadly sold vp s
    Oct 2009
    sa
    Default Defect
    ok i just want to know where do i measure from on my vp commodore to check if im 2 low. and what should the measurement be because i dont really want to be defected so if any1 can help that would be great
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Oct 2009
    sa
    most cars these days get measured from the centre of the wheel to the bottom of the guard. and i thought it was 100mm from the lowest point.
    also my hanbreak cable is really low on 1 side aprox 50mm off the ground could i be defected 4 that i have tryed to fix it but couldnt move it up
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by sawychri06 View Post
    Glad to see all the South Aussie's helping you out
    -320mm in the front and 280mm in the rear i think might be 270mm, 230mm for calais
    -You must still retain the 100mm ground clearence to your lowest point as well
    yes you can get defected for too low if there's not enough clearence under this cable. Stupid but true get it fixed
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by ducker85 View Post
    All VPs for the front are the same, 320mm.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Oct 2009
    sa
    any idea how i can move that handbreak cable up cause it pretty low. i think i might "just" be safe with the rest of the car. and do they take the measurement with people in the car
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    adding to that SA goes by 'eyebrow heights' so measure from your centre cap to the guard.
    adjust the cable tighter.
    OT anyone know what the handbrake changes (01.01.10) were to align the states? more relaxed for SA or tighter laws?
    Oct 2009
    sa
    yea i measure just then and im exact 280mm from the centre cap. but the hanbreak cable is the really solid part and i struggle to push it up and im worried if i try put a braket and screw it down it will just pull back through
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    Oct 2009
    sa
    yea they are i think coppas dnt pick on me cause i drive carefully and i have 16inch walkinshaws on it so there is still a little bit of tyre showin but not much so yea
  1. [SA] Defect
    By DARK SIDE in forum General
    Last Post: 10-11-2009, 01:40 AM
  2. defect?
    By DANNY8 in forum The Pub
    Last Post: 10-12-2008, 10:54 PM
  3. Defect ... :(
    By Ev0LuTioN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-02-2006, 12:49 AM
  4. regency defect
    By th1rt3en in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2005, 02:03 PM
