I have a 6cyl VN 5 speed Manual that has been sitting for over 2 years + it will turn over but I cant get it to start, any ideas?
Howdy Thanks for the input it has been very usefull, I can now get it to Fire (with Start Ya Bastard) but it wont run is the Fuel Pump an internal or external unit?
Replaced Fuel Pump Started First Time
Fuel pump would be my first guess... Get some 'start ya bastard' dump a good squirt in the intake and give it a kick or better yet get someone else to squirt it while you kick it over. Presuming you've checked for spark already?
Rotten fuel ? Fuel pump ? Spark ?
Check those things
Dirty big huntsman being a prick and blocking the injector ports?
Check the crank angle sensor. Could be grotty.
It's been sitting there for two years without being touched? Damn there are a dozen things i would do before even turning it over. I'm not touching this one with a ten foot clown pole, take it to a mechanic.
http://tinyurl.com/MetalisAwesome
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
I'm a mechanic. Get someone to smack the fuel tank while your cranking it. It's probably a fuel pump.
im gona say stale fuel, if theres not much in the tank top her up with fresh just and try again for awhile... maybe even pull a fuel line n ignition on to dump some ot first
Yeah, I'd empty the tank, fill up with new fuel, pull the fuel line and purge the old stuff into a can.
Warranty Void
