Results 1 to 6 of 6
Thread: changing a inlet manifold
    VX PC1 pack
    Jan 2010
    Default changing a inlet manifold
    i have to change the inlet manifold gasket on my V6 VN
    does any one have some tips for me, what are the hard bits, what should i pay speciel attension to?
    and does the gasket/s need any sealant put on or not, if so what sort?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Apply some ultra-blue around the water galleries. Other than that, just be really clean and take your time.
    Got a Gregories?
    a) If yes, use it.
    b) If no, buy one and refer to "a)"
    The 1972 HQ Kingswood
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Never removed mine before but the Gregories says to drain the coolant, can you get away with not draining it or draining only a little out?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    No, you need to drain the coolant, otherwise as soon as you lift the manifold off coolant will pour inside the engine, which is bad...
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Take care not to cross thread your manifold bolts or over-tighten them. I over tightened mine and it stuffed one of the valley seals. Ended up leaking worse than when I started .
    Give you manifold a good clean while its off too, can only help
    You'll find that the throttle body elbow gasket/s are somewhat hard to get on/off without tearing. If you doo tear it though its easy enough to make a new one up.
    I also like to place some rags over the valley while the manifold is off too keep any crap from falling in
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    If you do tear the throttle body and adapter gaskets, they don't much... about $3 each
  1. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  2. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  3. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  4. wtb: inlet manifold for vh
    By white vn ss in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2006, 12:47 PM
  5. changing inlet manifold gasket??
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2004, 09:17 AM
