Results 1 to 15 of 15
Thread: Radiator support panel?
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Default Radiator support panel?
    Hey guys, well today I went to a more reputable panel beater for a quote on my car. Now he said to do the job properly and square everything up the radiator support panel will need to be removed and a new one fitted. He explained and showed me why and it all makes sense, something the local joint never said a word about. And they dont even need the new panels to make sure it will all line up properly again, unlike the local joint...
    Anyway lol Im going to be the one to hunt one of these bad boys down. Now my question is, is the radiator support panel considered to be one panel? So if I demand Holden to give me one, will I get what I need? And if anyone knows, what ballpark figure do these sell for?
    Cheers.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VP Executive R-spec
    Jan 2005
    About 330 bucks for the top section, brand spank, but call Holden and see
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Top section? Is that the very top bit that reaches from one side of the car to the other? If so theres nothing wrong with that. I think Im needing the bottom section. I just thought it would all come as one piece?
    Im lost. Hence this thread
    Pic for clarity
    Edit: "top section" looks to be a bit damaged.
    My (ex)Ride
    VP Executive R-spec
    Jan 2005
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    hehehe I asked if it could be second hand and he said its not really worth it because of how its welded in with the chassis rail and whatever. Wreckers cant save me this time
    No doubt a cut and shut is possible but probably not there way of doing things.
    My (ex)Ride
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Well, no. It's spot welded together if I recall, and there's no neat (cheap) way of cutting and re-doing spot welds.
    The 1972 HQ Kingswood
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is online now Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    As a panel beater, i will say you can grind spot welds off second hand panels without any damage to the required panel/s. It's just a matter of knowing the right way to go about it... I've re-spot welded second hand panels, looks factory. Ring Holden and ask for a Radiator support Panel, it will come complete.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Cheers for the tip. I dont think I will attempt to salvage panels myself
    Waiting for a reply from Holden...
    My (ex)Ride
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    You can drill out the spot welds with a spot weld drill bit then the panels simply unstich.
    afterwards you can fill the holes from the drill with weld, and presto - re spot welded panel!
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Well Holden want $434.50 and said its all one piece. Thats a bit more than I was expecting. But I guess genuine parts for a 19 year old car would be getting limited.
    How many spot welds are we talking about? But I still dont think its a job for me though lol
    My (ex)Ride
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by VN_Luke View Post
    Got it in 1. Makes re-attaching it a neat and easy job actually. Done it a couple of time myself. Can be a bit time consuming to drill them out but shouldn't take more than an hour or so if the front end bits are off the car.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Jun 2005
    Yeh, drilling the welds out and plug welding it back on is good, but i prefer to grind the welds off from behind (leaves no holes in the panel you want) then spot weld it back on with a spot welder. Wouldn't even know it's been damaged. However, now that i'm out of the trade, i don't have access to a spot welder so plug welds it is
    Edit: $430 is too much to spend on a VN :P Get a second handie, the panel shop will probably hate you, but thats bad luck.
    yon
    yon is offline
    vn
    Mar 2006
    in the pic it looks as though u have serious chassis rail damage! might help if u get a car-o-liner chassis spec sheet and do some measurements and compare,then you'll know what u need for sure.thats what panel beaters will do first anyway,wont cost anything.seems u need more than rad support panel goin by pic,the whole front chassis could be pushed over(both rails).looks like u need whole left skirt & tower($200)+rail($400)new(maybe higher price now)+$400 for rad supp panel.you can get whole shell for $400 at wreckers.if panel beaters do it, the costs just keep snowballin to same price as buyin another car.hope this helps in some way.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Im 99% sure they will measure it all up. They advertise having a "car aligner measuring system" so I would hope they know what theyre doing. Ive been flat out at work so nothings been done this week. When Im not at work Im sleeping, and I get one day off this week so rebuilding a new shell is pretty much out of the question.
    1988 200TH ANIVERSARY MODEL VN COMMODORE - eBay, Restoration, Salvage, Cars, Cars, Bikes, Boats. (end time 25-Jan-10 06:52:46 AEDST)
    But I did find this gem on ebay and I would sooo buy it if I had the time (inspect it first of course) and mum wasnt complaining of wanting her car back . But I did also have the thought of buying a cheap run-around car for work, which also gives me more flexibility to do other things to the car and would keep the K's off it. Dont really have the room for another car here though lol
    Just a thought...
    My (ex)Ride
  15. #15
    manual vn commodor . turbo might be cool
    Jan 2010
    in the yarra valley
    me and the old man did all that . got one from pic a part that was white and now you wouldnt even know
  1. VS BT1 Radiator Support Panel.
    By lo-rolla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 07:02 PM
  2. radiator support panel swap
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2007, 10:36 PM
  3. Vr Vs Radiator Support Panel
    By Keesh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2007, 10:48 PM
  4. Radiator support panel for VS
    By shumway in forum Parts And Other Items For Sale
    Last Post: 17-02-2007, 11:24 AM
  5. Radiator support panel tag
    By Taz2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2004, 09:45 PM
