Results 1 to 4 of 4
Thread: VN mystery. No spark.
    Commotoro is offline Banned
    VN Commodore
    Jan 2010
    Default VN mystery. No spark.
    Ok first post here goes. Driving home form a mates place last night i went to take off and the engine just stoped after doing 10km. Coasted to the side of the road tried to restart and it wouldent, NRMA came and established there was no spark. Tow truck took the car home then this morning I tried to start it again and it kicked over straight away so i went for a drive and after 11 km same problem, no spark. Another tow home. this after noon after 6 hours of no spark i tried again and it kicked over straight away. Error codes come up with 12 - system ok.
    any ideas?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    It can be a few things - the most common being the CAS. Then the DFI unit or coils.
    Sometimes it can be the ECU.
    oh - and welcome to JC.
    and 3 Dangerous non ABS VN's
    VN Commodore
    Jan 2010
    Quote Originally Posted by 88GreenVN View Post
    Thankyou, I thaught it was the CAS but all other cases ive seen of the CAS failing it has logged the error and restarted soon after or straight away. Ill change it and see if i have any luck. how do you test the colis? it is a series 2.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Commotoro View Post
    With a multi meter - but I'm not up on how to do it.
    You could try swapping the ECU/colis if you know some one with spares.
  1. my little mystery...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 05:20 PM
  2. Mystery box
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 09:18 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. No spark to 3 and 6,Mystery problem
    By Veneficus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2006, 04:07 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
