Results 1 to 14 of 14
Thread: VN Sway bar link broken
    redlion05's Avatar
    redlion05 is offline Red Lion 05
    VY Calais Series 2
    Dec 2005
    Default VN Sway bar link broken
    I've got one of my bushes on the sway bar link fallen off and is creating a clunking noise when i drive over a bump or turn. Just wondering if doing it yourself is relativitely simple to do and as with most suspension, does it have to get wheel aligned? I'm driving a VN Calais
    VP Executive R-spec
    Jan 2005
    Yep it's pretty easy and no you wont need the wheels aligned, it's not part of that, the rubbers are only a couple bucks at Holden but they will break again if you drive in an agressive way. So it's best to upgrade the link pins and rubbers really
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Mate its a really easy job to do, and no you dont have to get a wheel alignment.
    Just a nut on either side of the pin, and a rubber and washer inbetween, really easy to do.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    And try to retighten the nuts when the suspension is resting at static height, not when the car is jacked up with the control arm hanging,
    The 1972 HQ Kingswood
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by Morton View Post
    Quite important, this.
    Sam
    WTB: mulberry VN interior parts
    VP Exec
    Jun 2005
    VP Executive R-spec
    Jan 2005
    And try not to forget the shifter that you left on it the pin, they make lots of noises when they bounce into your floor pan on the highway at a later date
    Fun_Bucket's Avatar
    Fun_Bucket is offline Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by greenfoam View Post
    How about when you haven't looked under the bonnet for a couple of months, then you pull into a servo, decide to check the coolant level, pop the bonnet, and find all those tools you've been searching for for 2 months!
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    Thanks everyone for your help. I have got a set of Natholine sway bar link kit for $55 today and realised that unlike the conventional links that came with the car (which are straight), my new ones are z shaped. I've been told there ok to use on my vn but was wondering if the z shape lines have to be faced a certain way?
    Also, I called a tyre place who does wheel alignments and they said that after i've replaced my sway bar links, it needs an alignment......i'm confused?
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Yes they have to be faced a certain way BUT if you install them right (grease the right places, correct tightnesses etc) they will self align fairly quickly I've been told.
    I'll check mine shortly for you to tell you how they should sit.
    Tyre places will always tell you you need a wheel alignment, I'm not 100% sure in your particular circustance with these different links. I'd say do one just for happiness they're only $60 ish.
    Sam
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    Thanks heaps Shane...your help (as with everyone elses) has been excellent. I definently get a wheel alignment just for safety since i ride on dusty and bumpy tracks. Please do let me know which way there to face....even place a photo...if you can. Many thanks
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    Quote Originally Posted by redlion05 View Post
    NEVER, EVER, EVER believe anything anyone from a tire shop says. If people would believe it they'd tell you you needed a wheel alignment every time you fill up with fuel
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OK. I don't have a pic as my links are not "Z" very agressively. I believe however that the lower end of the link should be the forwardmost end of the link on each side; the top (strut mount end) should be rearward of it.
    Should come with an instruction sheet depending on brand / stockist, so follow that to the letter and you'll be fine.
    Sam
    redlion05's Avatar
    VY Calais Series 2
    Dec 2005
    Thank you to every single one of you peoples lol I changed my sway bars using your instructions and it is back to its awesomeness state.....NO MORE CLUNKING!!!!
    AGAIN, THANK YOU ALL
  1. help me with sway bar link pin
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2011, 04:57 PM
  2. sway bar link kit
    By tug33r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2006, 10:27 PM
  3. Sway Bar Link
    By zuluchief in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 09:28 PM
  4. Sway Bar Link Mod
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 07:14 PM
  5. VN sway bar link kit??
    By stockVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 03:04 PM
