Hi guys.
I have done a search but can't find the answer. Whilest I was under the Commo installing a towbar I was having a look and feel around.
I noticed that I could move the the tailshaft around where the centre bearing is, should there be movement.
There is no grease leaking out.
Cheers Dazz
VN BT1 Mock Up Commodore
Dynamic Locksmiths
depends how much its moving. If its just a couple of mm you should be fine, if its any more that this your centre bearing is probably on the way out. Is the rear end vibrating at all?
The center bearing is rubber mounted.
nah its sweet they do move a bit mines a manual and it seems loose as but its still good 230K still kicken on. dont stress
Thanks guys, the cars only done 34,000km so I would have been suprised if it was shagged
Dazz
Dynamic Locksmiths
34000 genuine kays? thats insane! where'd you find it?
Nah bought it from a car yard, old guy owned it since new and came with service books
My new Time Capsule VN
Dazz
Dynamic Locksmiths
