can i put a VS cluster in a vp?
i know it will fit but i have heard that it will overheat and smoke!
any help please.
You have to change the PCB board at the back of the cluster otherwise you'll get the problems you've mentioned
Will fit in perfectly though
If ignorance is bliss why aren't there more happy people around ?
You can fit all the gauges and speedo from the VS cluster into your VP cluster.
But as said above - put a VS cluster into your VP and it WILL go up in smoke.
and 3 Dangerous non ABS VN's
zap-zap-hisssssssssssssssssssssssssssss.
The 1972 HQ Kingswood
thanks Guys, you have saved me frying a cluster!
is changing over the pcb as easy as taking the cluster apart and swapping over the pcb?
i am a handy sort of person but i have never pulled a cluster apart. if it is a matter of a few screws and a simple dismantle i am sure i can handle it. will i be fine or to i need a higher technical background?
thanks guys,
you have all been a great help.
i will work on it this weekend!
cheers
