Results 1 to 4 of 4
Thread: Air con repair and blown fuse
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    Default Air con repair and blown fuse
    Howdy
    My air con is stuffed, totally dead , it was dead when I aquired the car.
    I have also removed the air con hose too, once when I was putting on new mounts.
    So I am wondering what is the damage to get it regassed and ship shape again.
    I have about $200 so I am scraping it in, but what would be the best way to get around this problem. Any way of getting a realistic quote that I dont have to pay for before the work is done.?
    It might need more than a simple re gas.
    Also the fan only works on speeds 3 and 4, and I remember somone telling me it is some kind of blown fuse, any ideas.
    cheers
    Dan
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    $200 should get you a re-gas.
    To get a diagnosis done on the aircon system then you would probably need to pay for a shop to do it regardless.
    If its totally dead, budget around $1700 for new compressor, condensor, other bits and pieces and labor.
    VH Commodore
    Jan 2010
    The heater resistor will be causing the fan problem. Leaving an A/C system open to the air isn't agood thing to do and if you dint plug the ports at all then the chance are the compresor is full off shit.
    VP Exe
    Jan 2010
    Air con works now, I replaced the resistor (repco dont stock VP resistors so I just went and got one from the wrecker $5.00) and O rings on the compressor, had it regassed and leak checked ($150.00 for the guy to come around and do it).
    Fans a bit noisy on speed number 4, but saves me from roasting at the lights.
    Dan
  1. Blown fuse
    By flopat in forum Electrical Wiring / Questions
    Last Post: 07-06-2008, 10:36 PM
  2. blown fuse?
    By rbrtm in forum Electrical Wiring / Questions
    Last Post: 02-04-2006, 05:09 PM
  3. Blown the main fuse :(
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 09:50 PM
  4. VS wiring, possible blown fuse? please help
    By vs0001 in forum Electrical Wiring / Questions
    Last Post: 16-06-2005, 09:05 PM
  5. park light fuse blown
    By DustyV8 in forum General
    Last Post: 03-05-2005, 01:37 PM
