Results 1 to 6 of 6
Thread: Will it fit
    tailhappy vn is offline I H8 FORDS
    vn 5ltr auto vr v6 5spd vt v6 wagon
    Mar 2009
    sydney
    Exclamation Will it fit
    HI ALL I AM WONDERING IF A VR-VS DASH WILL FIT IN A 89 VN OR IF ANY1 HAS DONE THIS AND WILL THE WIRING LOOM FROM THE VR-VS DASH PLUG INTO MINE WITH NO PROBLEMS.. BOTH LOOMS R EXECUTIVE...
    VS Berlina 3.8
    Dec 2008
    The entire dashboard or the cluster?
    The dash will bolt in, but the cluster will go up in smoke if you put it in a VN.
    ALSO, IT HELPS US IF YOU DON'T WRITE IN CAPS.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    To PUT IN A VR DASH YOU NEED VR DOOR TRIMS, DUE TO THE AIR VENTS...
    The Black Beauty
    Mar 2009
    sydney
    Yea thanks i just wasn sure if the dash bolted up the same or was the same width
    Mar 2009
    sydney
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Clusters run a different EVERYTHING and will explode on impact. True story.
    The whole dashboard can be done, but if you want to do it properly with vents and all, it's a niiice big job Check out the "my ride" thread of a VN by the user HoZy.
    The 1972 HQ Kingswood
