Results 1 to 6 of 6
Thread: vs diff into a vn
    BIG DYL's Avatar
    BIG DYL is offline BIG DYL
    1998 VT Berlina
    Dec 2009
    adelaide
    Talking vs diff into a vn
    hey will a vs diff fit into a vn commodore
    HSV472's Avatar
    HSV472 is offline i just got one
    hsv vr clubsport
    Jun 2008
    s.e melb
    BIG DYL's Avatar
    1998 VT Berlina
    Dec 2009
    adelaide
    Quote Originally Posted by HSV472 View Post
    i would say yes as long as its a solid diff and not irs
    yer it a solid diff
    VP Exec
    Jun 2005
    The complete assembly, axle to axle? No.
    Well it can be physically bolted up to the control arms and Panhard rod (I've seen it done) but they are not interchangeable. VR/VS live axle have a different (wider) track to VN/VP. The difference is not great (look it up) but the car will drive (handle) noticeably strangely.
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    Thanks Cheap6, My VN has a VR diff in it which was there when i bought it and you may have just solved my strange floating feeling from the rear end that I always attributed to the adjustible panhard rod being off centre, however didn't go away when i aligned it. The diff is rooted anyway and needs replacing so hopefully this makes my baby feel a bit more planted
    BIG DYL's Avatar
    1998 VT Berlina
    Dec 2009
    adelaide
    Talking
    Quote Originally Posted by Cheap6 View Post
    ok i was worndering if it would go coz my vs diff is a lsd and my vn in an O/W.... can i switch the gearing inside the diffs or will it fell the same
  1. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  2. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  4. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
