hi there
i just got a vortech v2 supercharger i just want to know what size injectors to run and what size fuel pump i herd some one say the supercharge V6 fuel pumps work ok but im not sure about that its a vp V8 stock motor an if you know if i can get a chip to set it all up any helpers
maybe green top injectors bosch 42lb
2 bar map sensor
Bosch 040 Fuel Pump Specs:
Bosch Part Number: 0 580 254 040
Minimum Current: 12 Volts
Operating Pressure: 94 PSI (6.5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In Tank
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 930 Grams (2.05 Pound
not sure but maybe that might work?
when i get it fitted i will have a gillmore drive with power steering pulley for sale and cold air intake k&n filter is about 2 weeks old still got box for it
