Results 1 to 4 of 4
Thread: VP aircon pump pulley
    vp Executive
    Aug 2009
    Question VP aircon pump pulley
    hi, any one know if pully on vp aircon pump can be removed while still on engine
    coz it has a very noisy bearing.
    Kind Regards
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    You might as well remove the whole thing, you dont need air con?
    Just remove it, but you will need a different sized belt either way.
    I would go and buy another unit from the wreckers and replace it, you never know when you might want air con. -keep the belt the same and still have air con option.
    Dan
    VH Commodore
    Jan 2010
    Some models came without A\C so just get the belt for a non A/c model and leave the compressor on.
    VP Exec
    Jun 2005
    Yes, you can remove the pulley from the A/C compressor and replace the bearing that the pulley spins on when the compressor clutch is disengaged.
    To get the pulley off, undo the nut that holds the clutch plate on - unplug the wire to the compressor and jumper the connector on the compressor to battery power to temporarily lock the clutch and stop the clutch plate from spinning (leave the accessory drive belt on up to this point). Keep the washers (if any) behind the clutch plate as they set the gap between the clutch plate and compressor pulley.
    Remove the circlip that holds the pulley bearing onto the outside of the compressor snout and remove the pulley from the compressor. It's a light press fit on the snout so you'll likely need a puller. There is one type available that fits in between the bearing cages, after drilling the spacer/guide for the balls (destroying the bearing). The legs for the one I have aren't long enough to get past the compressor snout so, as an alternative, I made a couple of custom legs by welding segments of an old circlip onto 20mm flat bar. These engage in the circlip groove in the compressor pulley (it's only a light press fit). The compressor clutch solenoid will come off also.
    With the pulley and clutch solenoid removed, the bearing can be pressed out of the pulley for replacement. You need to be careful about supporting the pulley so as not to bend the clutch face while pressing the bearings out and in. Press on the outer race of the new bearing only - as per standard practice. There will be a circlip or two in there somewhere too.
    Reassembly is the reverse of removal with the only extra thing to do being to set/check the air gap between the compressor clutch plate and pulley using feeler gauges. I'm not sure what that gap is off the top of my head - possibly 0.8-1mm. You should be able to find it somewhere in the www: the V6 Commodore compressor should be a Sanden TRF or TRS 105. Otherwise, measure and match what the gap is now, acknowledging that the old bearing may have sufficient play in it to affect the gap. Tap the new bearing, with pulley, onto the compressor snout with a hammer, using a length of pipe or socket so as to only push on the inner race of the pulley bearing.
    Edit: I forgot to say not to push against the compressor shaft with the puller when removing the pulley. Use a large socket or a short length of water pipe with a diameter just smaller than the ID of the pulley bearing with some flat plate or bar across the end of it to push against the compressor shaft bearing housing (but not the compressor shaft bearing).
    Last edited by Cheap6; 26-01-2010 at 01:00 AM. Reason: Added detail about not pressing on the compressor shaft with the puller
  1. Water pump pulley
    By nathg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2009, 07:51 PM
  2. [VIC] WTB: SC14 6PSI Pulley & 12Psi Pulley
    By Bz Kn33z in forum Swap / Wanted to Buy / Trade
    Last Post: 20-05-2009, 12:08 AM
  3. Stuck bolts on pump pulley - Any thoughts?
    By Radar in forum General
    Last Post: 12-09-2008, 05:57 PM
  4. WTB: VN-VS V8 Power Steering Pulley Or Pump
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 29-04-2008, 01:21 PM
  5. tightening water pump pulley bolts - how!?!!?!
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 10:30 AM
