Results 1 to 5 of 5
Thread: noisy fan or compressor??
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    Default noisy fan or compressor??
    Hi all
    The fan behind the glovebox is hell noisey since I got it regased.
    I removed a leaf from it as I ca reach into it from the front.
    Not sure why it is so noisey.
    Any ideas?
    Do you have to remove the dash to get at these?
    Dan
    VH Commodore
    Jan 2010
    The bushs in the fans wear and they can make a lot of noise. If it is the fan then put up with it or sell the car.
    VP Exe
    Jan 2010
    what sort of a response is that?
    I cannot afford to sell the car, its all I ****ing have to get to work in, I cannot afford to push the **** into a ****ing mechanics everytime it shits itself.
    I was simply asking for a way to fix it, I assume by your rersponse you mean that the whole dash has to be removed (somthing I have done 3 or 4 times, but **** me it was a pain in the arse) to access the fan.
    cheers
    Dan
    VH Commodore
    Jan 2010
    You have pulled the complete dash and heater assembly out 3 or 4 times? Anytime you take a dash out of these models you always fit a new fan, a new heater core and a new evaporator because you never, ever want to do it again.
    VP Exe
    Jan 2010
    yes , that probably why I have so many problems with it.
    cheers
    I will put up with the noise until I get the courage up to face that task.
    Dan
  1. noisy fan vr v6
    By slick1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2009, 03:36 PM
  2. Noisy Air Con Compressor
    By sutto in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2009, 01:24 PM
  3. Noisy A/C compressor VR
    By vl_davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2008, 05:40 PM
  4. Noisy 3.8
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-04-2008, 12:39 PM
  5. Noisy Air Con
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2005, 01:56 AM
