Results 1 to 13 of 13
Thread: VP auto slipping problem
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    Default VP auto slipping problem
    Hey guys. My 92 VP is slipping, pretty sure it's the tranny but I've read about another auto where it was the torque converter.
    It's the worst when it's cold and slips like it's out of gear and just rev's.
    It's also missfiring if this has any relevance to it.
    Any ideas? I'll take it to an auto specialist but just looking if there's anything I should know here 1st.
    Cheers, Ryan.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    check the tranny flulid. may need a service
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    06 VE SS
    May 2009
    Rockingham, WA
    your gear box sounds like its on its ass and about die,just look for a good second hand one(if theres such a thing)or rebuild the one you got,it will cost big $.Iam getting a rebuild done on monday and its costing me about $1,000.But just Check the tranny fluid and do a service as said above it could just be blocked filters
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    when was the last time you changed the fluid and trans filter?
    Shitty old trans fluid will cause it too slip.
    Dan
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    prob the clutches have burnt out, im gettin mine rebuilt atm, its not cheap with some parts...mine was doin the same..but mine also was fine in first, changed into second then at 2500 would slip and hit limmiter and wouldnt change into 3rd.
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    Dr.304 is offline SuperCharged StatesMan
    1997 VS Statesman Supercharged
    Feb 2007
    Oz
    I just bought a VQ statesman V8 and im having the same issue.
    When in drive the gears slip when changing from 3rd to 2nd when im punching the throttle...is that normal?
    But if i put the car in 2nd and give her some, its doesn't slip? my car has 245,000kms 1 owner since new - i just think the tranny has been neglected (as in not serviced regularly) Im going to put her in for a service.
    Vp S IRS 6 Banger
    Jul 2009
    I got my tranny rebuilt 20,000km ago, Its not even shift kitted yet but will still chirp second if i hold it out in first.
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    having same issue, have a vr motor in my vn... reving out more than normal in first and slips like it pops out of gear and revs and then kicks in... clean and new fluid... motor a1 and full service... dont have much money at the moment so hopefully can find a cheap solution... just want it to have more bite and kick into next gear.... box has the 2 drive shifts.. OD aswel as D.. not like the new power buttons next to the shift
    Feb 2007
    Oz
    I took my car to my mechanic today.
    Asked for a full transmission service as you do. I also thought the car had a power steering leak. WRONG.
    One of the hoses going from the tranny to the cooler plate was split and leaking bad. When he dropped the tranny fluid he said there was only like 2 litres in there!! god damn!
    Thats 2/5's full. Thats not good. Hopefully when i get her back it will be smoother shifts and no more slipping?!! i hope. Also changed the diff oil - said it was very dirty.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    low fluid will make it slip like a slipperly bitch haha. hopefully there isnt too much damage done and yea a full sump of FRESH fluid will make it so much better.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Feb 2007
    Oz
    Yeah i reckon.
    The mech flushed it, refilled it - went for a drive.
    Then flushed it again and refilled it again. Shifts are good now.
    VP Exe
    Jan 2010
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    fluid is reading full :S so yeh i dunno might go see bro inlaw at his workshop hopefully can fix it cheap
  1. VE SS 6Sp. Auto, Slipping??
    By hdg_05 in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-09-2009, 11:14 PM
  2. auto slipping
    By fordsuck in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2009, 12:53 PM
  3. Slipping Auto
    By Tibokan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2008, 10:28 AM
  4. Slipping Auto
    By slipstream001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2008, 02:14 AM
  5. Auto Slipping
    By davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2004, 12:00 PM
