Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Sticky Fuel Gauge
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Sticky Fuel Gauge
    The fuel gauge copped a pounding today. I smashed it with a sledge hammer.
    After months of it working - then not - then yes - then NOT. So today it became many parts of a fuel gauge. RIP.
    Now having done this to the gauge - I get to thinking what made it fail some times. Hmmmm. cant do it now can I.
    So now I'm looking for a few local's (having the same issue of sticky L3 fuel gauge) to try a spare gauge of mine to see if it fixes it - if so, then try and work out why it fails. PM me if you live south of Adelaide and would like a free replacement gauge to see if it fixes the problem.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Dont know if hurts a fuel gauge - but I put 12 volts into one today. Moved the needle every time and quick too
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    the gauge probably works on resistance from a position sensor in the tank.
    somthing like
    4 - 20 milli amp
    empty full - being 4 milli amp is empty and 20 is full.
    sounds like Holden might be using a very weak current to move the needle.
    Is the needle hooked up to any computer?
    Or is it completely analouge (raw signal)?
    I mean if what your saying that the 12 volt stops it sticking then maybe all you need to do is drop the resistance a little, by replacing any resistor with a slightly weaker one allowing a bit more current, then calibrating the new current range with the thing you where talking about at the rear of the gauge.
    Would have been better if you had a tank unit out of the car and a gauge as well.
    get a multimeter and read the volts/amps it uses (while in car), set it up on a table with a 12 volt battery mimicking the car set up and go for it.
    Chances are it uses 12 volt and the resistor is built into the gauge and sender unit, so a straight 12 volt battery might be all you need to hook up
    (but i am not too sure there).
    Dan
    88GreenVN's Avatar
    Jun 2006
    I do have a sender unit and some dash loom wires. Should set it up proper hey. Then I can move the sender by hand and see if the gauge works correctly.
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    Quote Originally Posted by 88GreenVN View Post
    If only I lived a little closer
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Shane: I'm guessing this is what you have been planning to try?
    You should try set it up at home what vp commo says seems to make sense ay.. Be very interesting to try..
    Check It Out
    My 93' VR Executive
    1989 VN Wagon/ 1987 VL Exec.
    Nov 2009
    S.E 'burbs of Melb.
    Sounds like it would be the wires/resistor causing the problem though rather than the actual gauge if it never sticks when you apply a voltage to it. Does it noticeably pause when you apply voltage or does it move too fast to see?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Shearer View Post
    PM sent
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Insomniacs Dream View Post
    The unit I was testing was not the faulty one. I smashed the the faulty one in temper and now cant test it. Thats why I'm looking for a replacement sticky gauge
    88GreenVN's Avatar
    Jun 2006
    Gauge and voltage regulator sent to you for a good old testing
    Replace the gauge first to see if it is still sticking or not. If so then replace the voltage regulator and put your old gauge back in.
    If your gauge is the bit that is sticking - can you send it back to me so I can see if I can find the fault/fix for it.
    Cheers.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Best way to test would be to set the gauge and sender up on the workbench with 12 volts from a battery. If you use a battery charger for testing components you can get weird shit happening because the 12v DC ain't clean, theres 50hz fluctuation in it that will affect frequency sensitive instruments.
    Check the wiring to and from sender/gauge with a test light and give it a good wriggle to check for internal breaks. Both sender and gauge could have areas of resistive/induction coils winding shorted, giving ok behaviour up to a point then acting up then ok again.
    Good luck!
    Warranty Void
    88GreenVN's Avatar
    Jun 2006
    I've got a car battery in the shed and just zapped the gauge from that I also have a set of dash wires and sender unit already to go into a "test bench" so I can test the callibration of gauges. The L3 units all seem to be on the low side (read empty well before they are).
    This all came about because my gauge would stick even after trying several voltage regulators. Change the gage and the problem went away.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    What i noticed on a dash I got once was when the car got left in the heat, the little pin the needle sits on that's painted black heats up enough to make it sticky and the needle would stick to it needing a bash to dislodge it.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    So Shane got any updates on sticky fuel gauges in general (not just mine)?
    Did you set up the sender unit etc.. on a bench and test it that way?
    Check It Out
    My 93' VR Executive
  15. #15
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by mischa View Post
    Yep that can happen too. Seen it a few time now. They clean up OK and work properly after that. I give the gauges the "flick test" when putting cluster back together.
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by <VRCOMMY> View Post
    Got it half done on the bench - just too much work on at the moment to get to it There are a heap of wires to sort through.....
    Your cluster is all back together.
  17. #17
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Sounds good, it sounds like a pretty hard task to do but definately worth it - helps narrow down everyones fuel gauge problem. Im dying to get mine perfect, I get jealous seeing Dads VY gauge go flying up everytime
    Okay awesome, did the RPM needle get sorted out?
    Check It Out
    My 93' VR Executive
  18. #18
    88GreenVN's Avatar
    Jun 2006
    Bin job. Shiney new second hand unit in it's place. (cant trust the old one now)
  19. #19
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Oh right, cheers.
    So you tested the fuel gauge in your car - worked fine every time correct?
    Check It Out
    My 93' VR Executive
  20. #20
    88GreenVN's Avatar
    Jun 2006
    Oh right, cheers.
    Yep. that it did.
  21. #21
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Alright, will be interesting how it goes in my car. If it turns out sticky in the VR what do you think would be some good things to check?
    Check It Out
    My 93' VR Executive
  22. #22
    88GreenVN's Avatar
    Jun 2006
    I'd say it will be he voltage regulator - the thing that goes into the middle of the cluster. I've replaced that too.
    Fingers X'ed all will be good.
    With the L3 you can use the diag mode to test the voltage from the sender unit. The sender may have a bad connection and not sending the corect volts through to the gauge. (the plug at the fuel tank)
  23. #23
    Dec 2005
    S.A
    Cheers.
    I'm going to try that right now....
  24. #24
    Dec 2005
    S.A
    The results....
    1) Shane's fuel gauge + My regulator = Gauge moved instantly
    2) Shane's regulator + My crappy fuel gauge = Same (required a 'small' tap)
  25. #25
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Shearer: Sounds good mate, luckily for you it was only simple.
    I gotta wait till I get my L3 cluster back from Shane and i'll test as well and post my updates.
    Check It Out
    My 93' VR Executive
  1. Solution to Sticky fuel/temp guages
    By Gosling1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2011, 08:05 PM
  2. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  3. Sticky Fuel & Temp Guages
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2006, 09:27 AM
  4. sticky fuel & Temp guage
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2005, 10:48 PM
  5. Sticky fuel guage - the common problem
    By brettkp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2004, 11:46 PM
