Results 1 to 9 of 9
Thread: Grinding/vibrating when braking
    skunks.monks's Avatar
    skunks.monks is offline The one that you missed
    Toyota Lexcen (VP)
    Jul 2008
    Default Grinding/vibrating when braking
    So the last couple of days i have had a bad grinding/vibration in my 1993 VP commodore when braking. Does this mean pads need replacing or is there something else at fault?
    Check out my VP
    Wanted to Buy VP Front & Rear Bar/Bumpers
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Check the pads haven't worn down to the backing, or it will start chewing into your rotor, It wont hurt pulling it apart and having a look.
    brockee's Avatar
    brockee is offline (HOUSE OF POWER)
    VX S2 SENATOR SIG CAMMD A4
    Aug 2009
    mandurah> wa
    Toyota Lexcen (VP)
    Jul 2008
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    It can be caused by doing your wheel nuts up too tight, like with a rattle gun; other causes too but I cant remeber them. Its most common on fords, it will normally cause a shutter when breaking also. if there not too bad, you can get away with machining them.
    brockee's Avatar
    Aug 2009
    mandurah> wa
    breaking the speed limit every where, and heavy on the break pedal lolhahahahalso they do wear at some stage so theres probadly not much pad and rotor left ??
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    your probably down to the metal, but the vibrations hint at somthing else.
    Check your pads, I had this problem when I first bough the car, some dodgey person had put VN rotors on it and since the VP uses V8 rotors(few mm bigger in diameter) the rotor was too small causing the pad to only grip half the rotor and wear unevenly, eventually the brake pad started slipping out of position, causing vibrations/shudders.
    Dan
    Toyota Lexcen (VP)
    Jul 2008
    Toyota Lexcen (VP)
    Jul 2008
    Turns out my pads were ****ed! had about 1mm of meat left on them...
    Changed them over, smoother stopping now!
    Backs are ok for the time being though
    Check out my VP
  1. Grinding noise upon braking
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2011, 03:03 PM
  2. Vibrating
    By skinnyscotton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2008, 07:56 AM
  3. Little Help: Surging / Vibrating
    By Necrum_McDirk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 10:07 PM
  4. Vibrating car
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 05:16 PM
  5. Vibrating VS.....HELP im going nutZ
    By ghostVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 08:41 PM
