Results 1 to 6 of 6
Thread: v8 level 2 cluster into vn v6?
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    Default v8 level 2 cluster into vn v6?
    i just got a vn bt1 level 2 cluster for my vn but its for a v8 and because my car is a v6 im just wondering if i put it in i know the tacho wont read properly but will everything else work fine until i find a v6 level 2 tacho to put in
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Yeah everything else will work, you can change some resistors around, and it will work. I did it in my cluster because it was out of a VQ V8.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by NOT.BT1 View Post
    Yep it will work - the temp gauge will be a little different reading too - but nothing to worry about.
    and 3 Dangerous non ABS VN's
    NOT.BT1's Avatar
    Nov 2006
    geelong victoria
    ok thanks guys ill get onto it
    Instant Failure!
    vn ss,vl turbo, ktm 525,vs bt1
    Sep 2010
    shepparton
    probley a stupid q's but does this work vice-versa, v6 cluster too v8 dash? LEVEL 1
    tacho sticking, fuel gauge faulty (runs out at 1/8th) ,speedo sticks all the common stuff on vn's.
    cheers
    ,Do not argue with an idiot. He will drag you down to his level and beat you with experience.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by 5LTRVNSS View Post
    cheers
    The voltage regulator may be the problem with your cluster. It may just need a little solder oin the joints as they crack and the cluster stops working. You can run a V6 cluster in a V8 car - just the tacho reads wrong. The temp gauge is a little out but not too much.
    I've converted some VR L2 V6 tacho's to V8 and may need some one to test it out. Let me know if your interested
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. replacing level 2 cluster with level 3
    By Matt_vp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2010, 09:30 PM
  3. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  4. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
