Results 1 to 4 of 4
Thread: dash conversion
    Wardy5441 is offline Vn wanting more power
    vn executive
    Apr 2008
    croydon
    Default dash conversion
    hi im newish to the forums i was wondewring if the calais loom will plug straight into my executive loom for the dash and my fuel gauge is saying im always on 1/8 of a tank even after i jus filled it but when i hit a bump sometimes it goes to full i have relpaced sender 3 times cluster plug to the sender and ran a wire from sender to cluster any ideas im stumped could it be the cluster not groundinmg out
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Voltage regulator in the cluster or faulty fuel gauge.
    To get the calais cluster to work you will need to make a patch loom up with the the 4th plug.
    Replacing the whole loom in the Vn is a big ish job - patch loom is much quicker.
    and 3 Dangerous non ABS VN's
    vn executive
    Apr 2008
    croydon
    ok well i can put a wire to join the 2 wires in the sender plug and the gauge goes straight to full would that mean i might need a new fuel tank
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Wardy5441 View Post
    Would not think so.
    Pull the cluster out and then the speedo head, The voltage regulator is inside the cluster. Pop the regulator PCB out and inspect the solder joints for cracks. Very very common problem. Resolder any sus joints and your gauge should work much better after that.
    If you have to bash the dash - fix the regulator.
  1. VQ dash conversion in VN
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 11:05 PM
  2. VZ SS dash conversion
    By Smashn2nd in forum Electrical Wiring / Questions
    Last Post: 19-07-2009, 09:01 PM
  3. VX SS - Dash Conversion
    By nolim8ts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2008, 09:44 AM
  4. a SERIOUS vs dash conversion
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2008, 11:17 PM
  5. VN/VY Dash conversion
    By hotrod32 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2006, 10:04 PM
