sure its been covered but carnt find the link, anyways im looking for a how to remove pacemaker extractors on a vp v6 commodre, my drivers side headder has cracked ! god knows how ,but anyways i need a how to remove them so i can fix and install again.and a how to remove a sump off of a v6 without pulling the whole motor out
Real cars don't power the front wheels, they lift them
Would be much easier if you could drive it to a shop to get it done, repairs are usually pretty cheap.
But if you must remove yourself, undo the 2 flange bolts were the pacemaker’s end use CRC to make it a little easier.
Then undo the 8 or so bolts from the engine bay.
To remove the RHS header the rack has to be undone and pushed as far to the right as possible.
