Hi all
The gear changes have been poor lately and when I looked under the bonnet at the kickdown cable I can see that the plastic adjuster is not gripping the cable so it cannot be adjusted correctly, it's slipping.
On further inspection I noticed the bloody thing is attached to the cable and the plate on top of the TB.
Is this right? Or can you remove the adjuster from the cable and plate?
Dan
update- I fixed it, but it does appear to be slipping at times, I had to get a screwdriver and pull the button back out a bit.
Better get a new one soon I guess, or prolly just get one from the wreckers....depending on the cost
cheers
Dan
