Results 1 to 12 of 12
Thread: Handbrake Warning Lamp Fail
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Handbrake Warning Lamp Fail
    Why would my handbrake warning lamp not work? The other day I drove to the shops with the brake on. I've tested the globe and it works fine.
    What else controls the warning lamp to be on when the car is moving and handbrake is on?
    Have I spelt the "brake" wrong? - dont look write some how...
    and 3 Dangerous non ABS VN's
    vx s pack II
    Jan 2010
    aLKIDA
    check the wiring near the handbrake
    there should be one wire going to the handbrake switch.
    this supplies earth.
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I know on my car that the wire that runs to the handbrake has a real dodgy connector on it, only held on by two strands of copper wire. It may have become disconnected here or the switch that the wire is connected to is faulty. I believe works that when the hand brake is raised it touchs the switch the wire is connected to and creates and earthed connection, therefore turning on your dash light.
    BTW i hope you have skinny hands or narrow pliers as its a bloody tight fit in there!
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by PRAVX II S View Post
    Hmm - will have to have a look at this area - I've not touch the console for a while - so was not thinking of the switch.
    It's a yellow wire from memory - the reverse wire is lt green. Probably one of those wires (hopes).
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by D3V14NT View Post
    It's console out then....
    And nope hands are not skinny - sounds like a job for my 13 yo lad.
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Quote Originally Posted by 88GreenVN View Post
    Yep its a yellow wire, it runs through the console and enters into the handbrake housing via a grommet in the passenger side then plugs in vertically to the little switch. I spent a good 20mins with pliers trying to get the little bastard to hook up last time I had to disconnect it. This is all out of a series 2 VP btw so I'm not sure if it'll be indentical on the VNs but I imagine it wouldn't be too far off if it is different
    1. 1990 VN Exec V6
    88GreenVN's Avatar
    Jun 2006
    It's a 91 VN so should be the same - in fact I think it's yellow in the VS I seen at the wreckers the other day (console removed).
    88GreenVN's Avatar
    Jun 2006
    Took the console out today and moved the yellow wire. (ign on) and the brake light lite up instantly.
    The handbrake chime still went off. Even with my trip computer in it. More Puzzle
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    The plot thickens. So the handbrake warning light is all sweet when stationary but won't activate when moving?
    1. 1990 VN Exec V6
    88GreenVN's Avatar
    Jun 2006
    ha - did not test that - betta go out again...
    88GreenVN's Avatar
    Jun 2006
    Nope the spare cluster chimes away with the handbrake warning and mine is silent. (chimes when I leave the lights on so the chime works).
    Both clusters have the same parts in them and the same PCB.
    88GreenVN's Avatar
    Jun 2006
    small test today - my cluster in - handbrake warning chime sounds when you lift the lever just a little. So now to work out why the other cluster chimes away even with the hand brake off.
  1. Handbrake Sensor Fail? Service Warning Reset Not Working?
    By social in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-10-2009, 06:50 AM
  2. Faulty Lamp warning
    By TVR-190 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2008, 11:15 PM
  3. SRS warning Lamp fault????
    By zammo05 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-11-2008, 09:23 PM
  4. Airbag Warning Lamp
    By VT_Boi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2007, 08:34 PM
  5. warning lamp check relay
    By Old fart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2007, 07:30 PM
