Results 1 to 8 of 8
Thread: stiff steering after replacement.
    VP 3.8 auto with modified Roofracks
    Jan 2010
    Red face stiff steering after replacement.
    I have changed my VP steering wheel for a VS wheel. The steering seems a lot heavier / stiffer since I have put the VS steering wheel on. If I tighten the nut holding it on right up the steering becomes really stiff so it is hard to turn. To have the steering that it flows freely the steering wheel has a slight wobble in it (very slight at two points). The new wheel is not a airbag one. The steering works fine I just want to know how or why it has become so stiff and if I can rectify it? Thanks
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Jan 2010
    No. the plastic covering was and is still loose. There is no feeling of scraping when I turn the wheel like it is caught on something. That said it must be rubbing on something somewhere?
    VZ SV6
    Jul 2006
    Newcastle
    I had a similar issue when fitting a VY wheel to a VZ.
    Turned out that the VY wheel had several posts on the back of it which were level with the mounting spline. On the VZ wheel, these were recessed slightly.
    I shaved a few mill off these posts on the VY wheel, fitted it and it worked perfectly.
    I'm not suggesting that anyone modify their wheel like this as it may not be legal or insurable, but it worked for me
    If you're not weird, you're not normal...
    LUMPY 8's Avatar
    LUMPY 8 is offline buddaboy1990
    VK V8 WAGS, The bannana (vp calais donor), VS BT1
    Nov 2007
    SAs biggest retirement village (victor harbor)
    i put a vs wheel on my vn ss and all i did was shave the tonge thingo off the back of the wheel a bit cause it rubs on the plastic bracket watch-a-ma-call-it that holds the indicator stalk on
    Wrecking VL factory V8 only a few bits left still have full dash/crash pad
    and have a vk 202 motor and 5 speed Make an offer want it gone
    Jan 2010
    Update. On reading these replies I did some further investigating and found that all of the above were correct. The tab thing-a-am-jig that switched off the indicator was ever so slightly rubbing on the plastic on the column. Also the horn contact ring was just slightly rubbing the plastic bit on the column also.
    So I stand corrected when I said it was not rubbing as it was. I thought it was not as I could not feel it grabbing anywhere.
    The fix: remove steering wheel, remove the BOS collar ring thing, take the horn contact ring off, fire up the dremal and start shaving about a mil and a half off the face of the collar. I left the tabs/nipples there for the horn contact ring placement and then glued the ring back into place and used the dremal to shorten the nipples. I put the wheel back together and put it on the column and it works like a dream. Now there is only about a millimeter clearance from the horn contact ring to where it was formerly rubbing.
    Thanks guys for your help and ideas.
    VZ SV6
    Jul 2006
    Newcastle
    Appreciate the update and the thanks...
    When doing my wheel, I was getting a bit frustrated and pissed off till my girlfriend spotted the difference between the two...
    bit embarrasing lol...
    LUMPY 8's Avatar
    Nov 2007
    im happy cause i was helpful
  1. power steering stiff?
    By mars6484 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-01-2010, 08:22 AM
  2. Stiff steering in water
    By CrimsonThunder in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2009, 01:43 PM
  3. steering wheel replacement
    By bdj_007 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2008, 09:40 PM
  4. Steering, stiff and loud?
    By dale1389 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2008, 11:13 AM
  5. VN Steering Rack replacement
    By Tom_1569 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2008, 12:34 PM
